Ana içeriğe geç
ZTE ZMAX Z970 Battery Replacement
Neye ihtiyacın var
  1. ZTE ZMAX Z970  Battery Replacement, Battery: adım 1, 2 resimden 1. ZTE ZMAX Z970  Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970  Battery Replacement: adım 2, 2 resimden 1. ZTE ZMAX Z970  Battery Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970  Battery Replacement: adım 3, 3 resimden 1. ZTE ZMAX Z970  Battery Replacement: adım 3, 3 resimden 2. ZTE ZMAX Z970  Battery Replacement: adım 3, 3 resimden 3.
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970  Battery Replacement: adım 4, 2 resimden 1. ZTE ZMAX Z970  Battery Replacement: adım 4, 2 resimden 2.
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970  Battery Replacement: adım 5, 2 resimden 1. ZTE ZMAX Z970  Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970  Battery Replacement: adım 6, 2 resimden 1. ZTE ZMAX Z970  Battery Replacement: adım 6, 2 resimden 2.
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Burak Cengiz
480 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G3, Boczar Spring 2018 USF Tampa, Team S17-G3, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G3
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Although I haven’t yet embarked on this task, I feel more confident in doing so successfully. I have watched the Youtube videos on this and none of them showed such things as the number and placement of the screws. They did give some idea as to the difficulty of it however.
Please continue to produce more of these instructional blurbs.
aikidoronin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 1,574
