Ana içeriğe geç
ZTE ZMAX Z970 Screen Replacement
Neye ihtiyacın var
  1. ZTE ZMAX Z970 Screen Replacement, Battery: adım 1, 2 resimden 1. ZTE ZMAX Z970 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Screen Replacement: adım 2, 2 resimden 1. ZTE ZMAX Z970 Screen Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Screen Replacement: adım 3, 3 resimden 1. ZTE ZMAX Z970 Screen Replacement: adım 3, 3 resimden 2. ZTE ZMAX Z970 Screen Replacement: adım 3, 3 resimden 3.
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Screen Replacement: adım 4, 2 resimden 1. ZTE ZMAX Z970 Screen Replacement: adım 4, 2 resimden 2.
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Screen Replacement: adım 5, 2 resimden 1. ZTE ZMAX Z970 Screen Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Screen Replacement: adım 6, 2 resimden 1. ZTE ZMAX Z970 Screen Replacement: adım 6, 2 resimden 2.
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Screen Replacement, Screen: adım 7, 1 resimden 1.
    • Heat up the iOpener for 30 seconds and place on top of the phone for 2 minutes.
  8. ZTE ZMAX Z970 Screen Replacement: adım 8, 1 resimden 1.
    • Wedge the opening picks into all the corners of the phone and lift until the screen comes off.
Sonuç
Ismail Jhaveri
159 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G3, Boczar Spring 2018 USF Tampa, Team S17-G3, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 1,186
