Giriş
When your memory card is full, you can follow these steps to install another microSD card in your iON.
  1. Peel the rubber cover for the memory card and USB port away from the goggles. Be careful not to completely remove the cover!
    • Peel the rubber cover for the memory card and USB port away from the goggles.
    • Be careful not to completely remove the cover!
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Push the memory card in until you hear it click. Pull your finger away.
    • Push the memory card in until you hear it click.
    • Pull your finger away.
    • If you pull your finger away too quickly, the card can completely pop out of the slot and could get lost!
    • The memory card will pop out about half way out of its slot.
  4. Pull the memory card straight out of its slot. Pull the memory card straight out of its slot.
    • Pull the memory card straight out of its slot.
Sonuç
Eric Flores
128 İtibar
9 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 6
Her zaman: 1,191
