Ana içeriğe geç
Zebra ZP 505 Peel and Present System Replacement
Neye ihtiyacın var
  1. Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: adım 1, 2 resimden 1. Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: adım 1, 2 resimden 2.
    • Orient the printer so that the bottom is facing up.
    • Remove the three P1 9mm screws located on the bottom of the printer and remove the lower unit.
  2. Zebra ZP 505 Peel and Present System Replacement: adım 2, 2 resimden 1. Zebra ZP 505 Peel and Present System Replacement: adım 2, 2 resimden 2.
    • Remove the P0 9mm screw.
    • Proceed to remove the cover.
  3. Zebra ZP 505 Peel and Present System Replacement: adım 3, 1 resimden 1.
    • Disconnect the harness.
    • Thread the harness through the hole on the right hand side.
  4. Zebra ZP 505 Peel and Present System Replacement: adım 4, 1 resimden 1.
    • Remove the peel and present system by utilizing a metal spudger.
  5. Zebra ZP 505 Peel and Present System Replacement: adım 5, 1 resimden 1.
    • Remove the peel and present system.
Sonuç
Brian Jagger
316 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G2, Banghart Fall 2017 Cal Poly, Team S8-G2, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 765
