Ana içeriğe geç
Zeepad 7DRK Power and Volume Button Replacement
Neye ihtiyacın var
  1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: adım 1, 1 resimden 1.
    • First find the power and volume buttons so that you are familiar with their location.
    • The smaller button is the power button and the larger button is the volume button.
    FixBot'a Sor
    Yorum Ekle
  2. Zeepad 7DRK Power and Volume Button  Replacement: adım 2, 2 resimden 1. Zeepad 7DRK Power and Volume Button  Replacement: adım 2, 2 resimden 2.
    • To open the tablet, use one of the soft-tip prying tools.
    • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
    FixBot'a Sor
    Yorum Ekle
  3. Zeepad 7DRK Power and Volume Button  Replacement: adım 3, 1 resimden 1.
    • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
    • This is what the tablet looks like when pried apart.
    FixBot'a Sor
    Yorum Ekle
  4. Zeepad 7DRK Power and Volume Button  Replacement: adım 4, 2 resimden 1. Zeepad 7DRK Power and Volume Button  Replacement: adım 4, 2 resimden 2.
    • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
    • In the second picture, the volume control button is shown. Again notice the small locator rings.
    FixBot'a Sor
    Yorum Ekle
  5. Zeepad 7DRK Power and Volume Button  Replacement: adım 5, 2 resimden 1. Zeepad 7DRK Power and Volume Button  Replacement: adım 5, 2 resimden 2.
    • Now remove the old or broken buttons, and replace them.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trevor Taylor
234 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 608
