Ana içeriğe geç
Zeepad 7DRK Speaker Replacement
Neye ihtiyacın var
  1. Zeepad 7DRK Speaker Replacement, Speaker: adım 1, 2 resimden 1. Zeepad 7DRK Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Begin by popping off the plastic yellow device casing with the soft tip prying tool.
    • Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
  2. Zeepad 7DRK Speaker Replacement: adım 2, 2 resimden 1. Zeepad 7DRK Speaker Replacement: adım 2, 2 resimden 2.
    • Once the device is opened, the speaker should fall out of its position.
    • Follow the red and black wires attached to the speaker to find the location of connection.
  3. Zeepad 7DRK Speaker Replacement: adım 3, 1 resimden 1.
    • The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
    • Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
Sonuç
Alexandra Souza
222 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G8
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 93
