Giriş
Replacing the cameras that may be cracked or faulty on your Zeki Droid Tablet. This procedure should take no more then twenty minutes to complete. The process will include using tools such as spudgers, and tweezers.
Neye ihtiyacın var
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Bu adımda kullanılan alet:Tweezers$4.99
Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
Bir başkası bu kılavuzu tamamladı.
