Ana içeriğe geç
Zeki Droid Tablet Camera Replacement
Neye ihtiyacın var
  1. Zeki Droid Tablet Camera Replacement, Back Casing: adım 1, 1 resimden 1.
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  2. Zeki Droid Tablet Camera Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the tapes one by one from the connecting wires with tweezers.
    FixBot'a Sor
    Yorum Ekle
  3. Zeki Droid Tablet Camera Replacement: adım 3, 1 resimden 1.
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
    FixBot'a Sor
    Yorum Ekle
  4. Zeki Droid Tablet Camera Replacement: adım 4, 1 resimden 1.
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
    FixBot'a Sor
    Yorum Ekle
  5. Zeki Droid Tablet Camera Replacement: adım 5, 1 resimden 1.
    • Pull the speakers away from the back casing carefullly.
    FixBot'a Sor
    Yorum Ekle
  6. Zeki Droid Tablet Camera Replacement, Camera: adım 6, 2 resimden 1. Zeki Droid Tablet Camera Replacement, Camera: adım 6, 2 resimden 2.
    • Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
    • The adhesive may make it difficult to remove the cameras from the tablet.
    FixBot'a Sor
    Yorum Ekle
  7. Zeki Droid Tablet Camera Replacement: adım 7, 1 resimden 1.
    • Undo the ZIF connector that is connecting the cameras to the motherboard using a plastic spudger or fingernail.
    • This guide has more information on how to undo the ZIF connector
    • Do not yank the ZIF connector. It should come apart very easily with little force needed.
    FixBot'a Sor
    Yorum Ekle
  8. Zeki Droid Tablet Camera Replacement: adım 8, 1 resimden 1.
    • Pull the copper connection carefully away from the motherboard of the tablet to completely remove the camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Colleen McFadden
268 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 629
