Ana içeriğe geç
Zeki Droid Tablet Front Screen Replacement
Neye ihtiyacın var
    1. Zeki Droid Tablet Front Screen Replacement, Back Casing: adım 1, 1 resimden 1.
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Zeki Droid Tablet Front Screen Replacement: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the tapes one by one from the connecting wires with tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Zeki Droid Tablet Front Screen Replacement: adım 3, 1 resimden 1.
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      FixBot'a Sor
      Yorum Ekle
    4. Zeki Droid Tablet Front Screen Replacement: adım 4, 1 resimden 1.
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      FixBot'a Sor
      Yorum Ekle
    5. Zeki Droid Tablet Front Screen Replacement: adım 5, 1 resimden 1.
      • Pull the speakers away from the back casing carefullly.
      FixBot'a Sor
      Yorum Ekle
    1. Zeki Droid Tablet Front Screen Replacement, Front Screen: adım 6, 1 resimden 1.
      • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Zeki Droid Tablet Front Screen Replacement: adım 7, 1 resimden 1.
      • Lift the camera and flash components from their fittings using tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Zeki Droid Tablet Front Screen Replacement: adım 8, 1 resimden 1.
      • Lift the metal framing to reach the components at the front of the device.
      • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
      FixBot'a Sor
      Yorum Ekle
    4. Zeki Droid Tablet Front Screen Replacement: adım 9, 2 resimden 1. Zeki Droid Tablet Front Screen Replacement: adım 9, 2 resimden 2.
      • Push the screen forward to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kyla
156 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G6
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 569
