Ana içeriğe geç
Zeki Droid Tablet Front Screen Replacement
Neye ihtiyacın var
  1. Zeki Droid Tablet Front Screen Replacement, Back Casing: adım 1, 1 resimden 1.
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Front Screen Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Front Screen Replacement: adım 3, 1 resimden 1.
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Front Screen Replacement: adım 4, 1 resimden 1.
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Front Screen Replacement: adım 5, 1 resimden 1.
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Front Screen Replacement, Front Screen: adım 6, 1 resimden 1.
    • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
  7. Zeki Droid Tablet Front Screen Replacement: adım 7, 1 resimden 1.
    • Lift the camera and flash components from their fittings using tweezers.
  8. Zeki Droid Tablet Front Screen Replacement: adım 8, 1 resimden 1.
    • Lift the metal framing to reach the components at the front of the device.
    • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
  9. Zeki Droid Tablet Front Screen Replacement: adım 9, 2 resimden 1. Zeki Droid Tablet Front Screen Replacement: adım 9, 2 resimden 2.
    • Push the screen forward to remove.
Sonuç
Kyla
156 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 405
