Ana içeriğe geç
Zenithink ZTPAD ZT280 C91 Back Panel Replacement
Neye ihtiyacın var
  1. Zenithink ZTPAD ZT280 C91 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: adım 2, 3 resimden 1. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: adım 2, 3 resimden 2. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: adım 2, 3 resimden 3.
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 152
