Ana içeriğe geç
Zig-zag Patch
Neye ihtiyacın var
  1. Zig-zag Patch, Zig-zag Patch: adım 1, 3 resimden 1. Zig-zag Patch, Zig-zag Patch: adım 1, 3 resimden 2. Zig-zag Patch, Zig-zag Patch: adım 1, 3 resimden 3.
    • Examine the damage. Clip any long, loose threads, and remove any debris from the hole.
    • Measure the length and width of the hole.
    • In our case it looks like 2" by 1".
    FixBot'a Sor
    Yorum Ekle
  2. Zig-zag Patch: adım 2, 3 resimden 1. Zig-zag Patch: adım 2, 3 resimden 2. Zig-zag Patch: adım 2, 3 resimden 3.
    • Grab a scrap of denim or other heavy-weight fabric and mark your measurements plus one inch in each direction.
    • In our case it will be 3" by 2".
    • Cut the scrap into a rectangle the dimensions of your new measurements.
    FixBot'a Sor
    Yorum Ekle
  3. Zig-zag Patch: adım 3, 2 resimden 1. Zig-zag Patch: adım 3, 2 resimden 2.
    • Insert the rectangle of fabric into the jean leg and position it under the hole.
    • Be sure that you put the rectangle of fabric in the pant leg and not behind it—you only want to work on one layer of fabric.
    FixBot'a Sor
    Yorum Ekle
  4. Zig-zag Patch: adım 4, 3 resimden 1. Zig-zag Patch: adım 4, 3 resimden 2. Zig-zag Patch: adım 4, 3 resimden 3.
    • Thread your sewing machine with your desired thread color.
    • Slide the pant leg onto the arm of the sewing machine.
    • You may need to remove the sewing machine table for the pant leg to fit over the arm.
    • Be sure that the pant leg is around the arm of the sewing machine. If both layers are stacked on one another, you will sew the pant leg shut.
    FixBot'a Sor
    Yorum Ekle
  5. Zig-zag Patch: adım 5, 3 resimden 1. Zig-zag Patch: adım 5, 3 resimden 2. Zig-zag Patch: adım 5, 3 resimden 3.
    • Check that the rectangle of fabric is still laying flat, centered beneath the hole.
    • Lower the pressor foot.
    • Sew a straight line over the hole going about five stitches past the damage.
    FixBot'a Sor
    Yorum Ekle
  6. Zig-zag Patch: adım 6, 3 resimden 1. Zig-zag Patch: adım 6, 3 resimden 2. Zig-zag Patch: adım 6, 3 resimden 3.
    • Lift the pressor foot.
    • Rotate the jean leg a few degrees toward the center of the hole.
    • Engage the backstitch function on your sewing machine, and sew a straight line back over the hole, going about five stitches beyond the damage.
    FixBot'a Sor
    Yorum Ekle
  7. Zig-zag Patch: adım 7, 3 resimden 1. Zig-zag Patch: adım 7, 3 resimden 2. Zig-zag Patch: adım 7, 3 resimden 3.
    • Repeat steps five and six, continuing to rotate and sew lines of stitching back and forth until you cover the entire hole.
    FixBot'a Sor
    Yorum Ekle
  8. Zig-zag Patch: adım 8, 2 resimden 1. Zig-zag Patch: adım 8, 2 resimden 2.
    • When you are satisfied with your stitching, backstitch two or three stitches.
    • Lift the needle and pressor foot.
    • Slide the jean leg off of the sewing machine.
    FixBot'a Sor
    Yorum Ekle
  9. Zig-zag Patch: adım 9, 2 resimden 1. Zig-zag Patch: adım 9, 2 resimden 2.
    • Clip any dangling threads and admire your work.
    FixBot'a Sor
    Yorum Ekle
  10. Zig-zag Patch: adım 10, 3 resimden 1. Zig-zag Patch: adım 10, 3 resimden 2. Zig-zag Patch: adım 10, 3 resimden 3.
    • Still not satisfied? Alrighty, let's add some decorative stitching the other way.
    • This is completely optional. If you are happy with your work, you can stop here.
    • Slide the pant leg back onto the arm of the sewing machine, making sure that the leg goes around the arm.
    FixBot'a Sor
    Yorum Ekle
  11. Zig-zag Patch: adım 11, 2 resimden 1. Zig-zag Patch: adım 11, 2 resimden 2.
    • Carefully rotate the jean leg 90 degrees.
    • Be sure that there is only one layer of fabric (plus the rectangle) between the sewing machine and the needle, or else you will sew the pant leg shut.
    FixBot'a Sor
    Yorum Ekle
  12. Zig-zag Patch: adım 12, 2 resimden 1. Zig-zag Patch: adım 12, 2 resimden 2.
    • Sew a straight line of stitching over the damaged area.
    FixBot'a Sor
    Yorum Ekle
  13. Zig-zag Patch: adım 13, 3 resimden 1. Zig-zag Patch: adım 13, 3 resimden 2. Zig-zag Patch: adım 13, 3 resimden 3.
    • Just like before, at the end of each line of stitching, lift the pressor foot, rotate the jeans a few degrees, and sew another line of stitching.
    • When you are happy with the way that the stitching looks, backstitch two or three stitches.
    FixBot'a Sor
    Yorum Ekle
  14. Zig-zag Patch: adım 14, 2 resimden 1. Zig-zag Patch: adım 14, 2 resimden 2.
    • Lift the pressor foot and needle.
    • Slide the pant leg off the arm of the sewing machine.
    FixBot'a Sor
    Yorum Ekle
  15. Zig-zag Patch: adım 15, 2 resimden 1. Zig-zag Patch: adım 15, 2 resimden 2.
    • Clip any dangling threads.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ta-da! Nice work.
8 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.963 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.236 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 69
Son 30 gün: 363
Her zaman: 39,568
