Ana içeriğe geç
Zoll Impact Uni-Vent 731 Battery Compartment Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Zoll Impact Uni-Vent 731 Battery Compartment Replacement, Battery Compartment Kit: adım 1, 1 resimden 1.
    • Remove the battery compartment cover by unscrewing the (4) Phillips 6-32 X 5/16 screws. This is indicated in red with the number 1.
    • Page 25.
  2. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 2, 2 resimden 1. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 2, 2 resimden 2.
    • Remove the battery by unscrewing the (4)Phillips 6-32 X 2 ¼ screws and detaching the plug from its locking latch. This is indicated in the second picture in blue with the number 2.
    • Page 25.
  3. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 3, 1 resimden 1.
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
    • Page 25.
  4. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 4, 1 resimden 1.
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) Phillips 6-32 X 5/16 screws provided.
    • Page 25.
  5. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 5, 1 resimden 1.
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) Phillips 6-32 X 2 ¼ screws. This is indicated in blue with the number 5.
    • Page 25.
  6. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 6, 1 resimden 1.
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X5/16 screws. This is indicated in red with the number 6.
    • Page 25.
  7. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: adım 7, 1 resimden 1.
    • Perform HiPot Testing then perform Functional Test using the RCS to verify the replacement is working properly.
    • Page 25.
Sonuç
Michaela Fromm
150 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Cal Poly, Team S1-G5, Zimmerman Spring 2020 üyesi
CPSU-ZIMMERMAN-S20S1G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 314
