Ana içeriğe geç
Zoom H1 Handy Recorder Battery Terminal Replacement
Neye ihtiyacın var
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: adım 1, 1 resimden 1.
    • Place the device so the display is down.
    FixBot'a Sor
    Yorum Ekle
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover, pressing down on the tabs and sliding.
    FixBot'a Sor
    Yorum Ekle
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 3, 1 resimden 1.
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
    FixBot'a Sor
    Yorum Ekle
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 4, 1 resimden 1.
    • Carefully pry up the top end of the back cover using one finger
    FixBot'a Sor
    Yorum Ekle
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 5, 1 resimden 1.
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
    FixBot'a Sor
    Yorum Ekle
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 6, 1 resimden 1.
    • De-solder at terminal point one.
    FixBot'a Sor
    Yorum Ekle
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 7, 1 resimden 1.
    • De-solder at the second terminal point.
    FixBot'a Sor
    Yorum Ekle
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 8, 2 resimden 1. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 8, 2 resimden 2.
    • Remove the faulty terminals
    FixBot'a Sor
    Yorum Ekle
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 9, 1 resimden 1.
    • Place new lead in at point one and re-solder at the point.
    FixBot'a Sor
    Yorum Ekle
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: adım 10, 1 resimden 1.
    • Place second lead at point 2 and re-solder.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To Re-construct device, perform these steps in reverse order.
Alex
809 İtibar
5 adet Kılavuz yazıldı
7Kılavuz Yorumları
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Yanıt Paylaş
Mine has third screw under the serial-number sticker.
halluciana - Yanıt Paylaş
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Yanıt Paylaş
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Yanıt Paylaş
Same problem, without any reason it is dead
eevilcute - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 7,442
