Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the battery cover, pressing down on the tabs and sliding.
Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
Carefully pry up the top end of the back cover using one finger
Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
Place new lead in at point one and re-solder at the point.
7 Yorum
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Mine has third screw under the serial-number sticker.
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
