Giriş
The power switch is located on the bottom, left side of the device. Connected to the switch is its circuit. When the switch doesn't work, it means that the circuit will have to be replaced. This will require the button board, as well as the motherboard, to be removed in order to reach the circuit.
Neye ihtiyacın var
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
With the bottom of the device on a table, lift the top of the device and gently place it aside.
Does anyone know where to buy replacement parts?
Hi I have questions where can I find sell for zoom H6 ?
Me too. I have contact Zoom but no answer..
Nacho -
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Olá como faço para comprar o display para esse gravador
Queimou o display do meu gravador h-6 vocês podem me ajudar
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
Use tweezers to lift power switch circuit out of device by the plastic ribbon connection.
Replace the power switch circuit.
Bir başkası bu kılavuzu tamamladı.
5 Yorum
where can i buy the power switch?
Are the parts available anywhere?
If anybody still needs parts, you can get them here: https://shop.audiotronic.fr/en/61-h6
You get get pretty much all the Parrrts for Zoom devices here:
https://shop.sonj.fr/en/3-zoom
