Ana içeriğe geç
Zoom Q3HD Handy Video Recorder Lens Cleaning
Neye ihtiyacın var
  1. Zoom Q3HD Handy Video Recorder Lens Cleaning, Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 1, 1 resimden 1.
    • Remove the two screws from the bottom of the device.
    • Make sure to put your screws in a safe place.
  2. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 2, 1 resimden 1.
    • Flip the device over and remove the four screws bordering the grate of the device.
  3. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 3, 1 resimden 1.
    • On the front of the device, slide the battery compartment cover off by pushing inward and sliding downward.
  4. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 4, 1 resimden 1.
    • Remove the two screws from the lip of the battery compartment.
  5. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 5, 1 resimden 1.
    • Remove the final screw from the bed of the battery compartment.
  6. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 6, 1 resimden 1.
    • WARNING: Pieces may become loose when you separate the device in half!
    • Run the pry tool along the edges of the device to begin separating the device in two halves.
  7. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 7, 2 resimden 1. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 7, 2 resimden 2.
    • REMINDER: Pieces may become loose when you separate the device in half!
    • Apply upward pressure to fully separate the device into two halves.
  8. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 8, 1 resimden 1.
    • WARNING: If you’re not careful with keeping the screen close to the board, you will rip off the ribbon attaching the screen to the circuit board.
    • Lift display screen keeping the top half close to the board.
  9. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 9, 1 resimden 1.
    • Gently flip the black clip up attaching the ribbon of the screen to the circuit board.
  10. Zoom Q3HD Handy Video Recorder Lens Cleaning: adım 10, 1 resimden 1.
    • Gently slide the ribbon from the circuit board, removing the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Grace Bently
4 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Mccook Fall 2014 Ohio State, Team 1-1, Mccook Fall 2014 üyesi
OSU-MCCOOK-F14S1G1
4 Üyeler
1 Kılavuz yazıldı
3Kılavuz Yorumları
My zoom q3HD only have the red light turned on when powering up. No display at all. What is happening? How can I claim warranty? I didn't use the device more than a year. Help me
stancalvin - Yanıt
This is not comlete, leaves you half way through, would be great if you could finish this, thank you.
smoldas.l - Yanıt
Yes it would be good to see it finished. I am half way through taking mine apart to clean the lens amd i don't know if i should proceed or not. Its the 2nd time the lens has fogged up. My 2nd q3hd.
steven kemsley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 2,290
