Ana içeriğe geç
Zoombak Personal GPS Locator Battery Replacement
Neye ihtiyacın var
  1. Zoombak Personal GPS Locator Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Zoombak Personal GPS device
  2. Zoombak Personal GPS Locator Battery Replacement: adım 2, 1 resimden 1.
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
  3. Zoombak Personal GPS Locator Battery Replacement: adım 3, 1 resimden 1.
    • Use a small tip flat blade screw driver to remove the rubber plugs.
  4. Zoombak Personal GPS Locator Battery Replacement: adım 4, 1 resimden 1.
    • Plugs removed
  5. Zoombak Personal GPS Locator Battery Replacement: adım 5, 1 resimden 1.
    • Rubber plugs
  6. Zoombak Personal GPS Locator Battery Replacement: adım 6, 1 resimden 1.
    • Remove the bottom cover.
  7. Zoombak Personal GPS Locator Battery Replacement: adım 7, 1 resimden 1.
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  8. Zoombak Personal GPS Locator Battery Replacement: adım 8, 1 resimden 1.
    • The old one was swollen from being on the charger for so long.
  9. Zoombak Personal GPS Locator Battery Replacement: adım 9, 1 resimden 1.
    • The case without the battery.
  10. Zoombak Personal GPS Locator Battery Replacement: adım 10, 1 resimden 1.
    • New battery installed.
  11. Zoombak Personal GPS Locator Battery Replacement: adım 11, 1 resimden 1.
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
James
113 İtibar
1 Kılavuz yazıldı
2 Yorum
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - Yanıt
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,247
