Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will assist the reader in replacing the tip of Zoomer Dino Boomer's tail.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer. Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer.
    • Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer.
  2. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  3. Use the spudger to pry open the two ridges on the last segment of the tail. Use the spudger to pry open the two ridges on the last segment of the tail.
    • Use the spudger to pry open the two ridges on the last segment of the tail.
  4. Remove the rubber tail tip from the plastic connector. Remove the rubber tail tip from the plastic connector.
    • Remove the rubber tail tip from the plastic connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lauren Mannix
392 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G1
3 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Where do I buy the replacement tail? Ours broke off!
supportchris - Yanıt
What about the rest of the tail? The strings on mine came unattached and the whole tail came off. I am unable to successfully get the strings reattached to the end of the tail.
Bob Essl - Yanıt
Where can I buy a new tail tip for the green dino?
Christopher Baldwin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 4,663
