Ana içeriğe geç
Zoomer Jurassic World Indominus Rex Mouth Gears Replacement
Neye ihtiyacın var
  1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: adım 1, 2 resimden 1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: adım 1, 2 resimden 2.
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 2, 3 resimden 1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 2, 3 resimden 2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 2, 3 resimden 3.
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: adım 3, 3 resimden 1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: adım 3, 3 resimden 2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: adım 3, 3 resimden 3.
    • After removing the tongue, inspect and remove any debris from the inside of the mouth.
    • Remove the four (4) 7.5mm phillips screws that are inhibiting your ability to successfully remove the motor inside the mouth.
    • Remove the two (2) 7.2mm phillips screws that fasten the motor to the inside of the mouth.
  4. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 4, 3 resimden 1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 4, 3 resimden 2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to remove the motor assembly from the mouth and inspect for any apparent issues.
    • Use a #1 Phillips Screwdriver to remove the two (2) 5.5mm phillips screws to remove the motor from the rest of the assembly.
    • Use tweezers to gently remove the motor from the rest of the assembly.
  5. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 5, 3 resimden 1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 5, 3 resimden 2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 5, 3 resimden 3.
    • Use tweezers, inspect the main output gear for the jaw and remove if necessary.
    • Remove the four (4) 4.9mm screws from the other side of the assembly.
    • Use a spudger to gently pry apart the assembly for inspection.
  6. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: adım 6, 1 resimden 1.
    • Inspect the gears inside the assembly and replace any gears that have flattened or rounded teeth.
Sonuç
Luke Selby
624 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 701
