Ana içeriğe geç
Zoomer Jurassic World Indominus Rex Nose Sensors Replacement
Neye ihtiyacın var
  1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: adım 1, 2 resimden 1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: adım 1, 2 resimden 2.
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: adım 2, 3 resimden 1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: adım 2, 3 resimden 2. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: adım 2, 3 resimden 3.
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: adım 3, 2 resimden 1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: adım 3, 2 resimden 2.
    • Carefully, pull out the circuit board that has the three nose sensors attached.
    • You're almost done! The only thing left to do is to use a soldering iron to remove the six (6) wires connected to the circuit board.
    • Use caution when soldering to avoid being burned.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Luke Selby
624 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 362
