Giriş
Here it is! The mighty Indominus Rex has fallen prey to mechanical failure. Let's get him up and running again.
Neye ihtiyacın var
Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
Gently remove the entire bottom jaw piece.
Carefully, pull out the circuit board that has the three nose sensors attached.
You're almost done! The only thing left to do is to use a soldering iron to remove the six (6) wires connected to the circuit board.
2 farklı kişi bu kılavuzu tamamladı.
