Ana içeriğe geç
Zoomer Meowzies Battery Replacement
Neye ihtiyacın var
  1. Zoomer Meowzies Battery Replacement, Battery: adım 1, 2 resimden 1. Zoomer Meowzies Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: adım 2, 2 resimden 1. Zoomer Meowzies Battery Replacement: adım 2, 2 resimden 2.
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Sonuç
Mitchell Gentry
675 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G2
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 901
