Ana içeriğe geç
Zoomer Meowzies Wheels Replacement
Neye ihtiyacın var
  1. Zoomer Meowzies Wheels Replacement, Legs: adım 1, 3 resimden 1. Zoomer Meowzies Wheels Replacement, Legs: adım 1, 3 resimden 2. Zoomer Meowzies Wheels Replacement, Legs: adım 1, 3 resimden 3.
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Wheels Replacement: adım 2, 2 resimden 1. Zoomer Meowzies Wheels Replacement: adım 2, 2 resimden 2.
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Wheels Replacement: adım 3, 3 resimden 1. Zoomer Meowzies Wheels Replacement: adım 3, 3 resimden 2. Zoomer Meowzies Wheels Replacement: adım 3, 3 resimden 3.
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Wheels Replacement, Wheels: adım 4, 1 resimden 1.
    • Turn the Zoomer Meowzies leg to its side.
    • Using the Triangle driver remove the two bottom 7 mm screws.
  5. Zoomer Meowzies Wheels Replacement: adım 5, 1 resimden 1.
    • Hold both sides of the leg and gently pull apart.
    • If pulled apart too forcefully the rest of the leg may sustain damage. Caution is advised.
  6. Zoomer Meowzies Wheels Replacement: adım 6, 2 resimden 1. Zoomer Meowzies Wheels Replacement: adım 6, 2 resimden 2.
    • Wheel should now be exposed. Pull wheel up and away from the rest of the leg to remove. Replace with new wheel if necessary.
Sonuç
Muataz Alahmadi
193 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G2
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 323
