Ana içeriğe geç
Giriş
We will be taking apart the main chassis, thigh section, and motor chassis to replace the front leg on the Zoomer Show Pony.
  1. Flip the pony over. Remove the five Triangle 3 screws from underneath. The pony will separate into a few pieces once the screws are removed.
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Disconnect all of the wires between the head and leg sections. To replace the power/volume switch, remove the two Phillips #0 screws from the switch. Lift the switch out to replace.
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
  3. Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. If you are not replacing the pony's speaker, skip the next bullet point. Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
  6. Remove all five triangular screws located on the backside of the leg. Remove the Phillips head screw holding the white leg bracket. The white bracket MUST be re-connected in the same orientation. Make sure to note which side is up and down. The part looks symmetric to the blind eye but it is not.
    • Remove all five triangular screws located on the backside of the leg.
    • Remove the Phillips head screw holding the white leg bracket.
    • The white bracket MUST be re-connected in the same orientation. Make sure to note which side is up and down. The part looks symmetric to the blind eye but it is not.
    • Detach the plastic mount at the top of the leg by sliding it in a vertical motion from the position shown.
  7. Lift up on the plastic housing located on the upper portion of the leg (where it connects to the body). Carefully separate the plastic housing at the base of the leg. Remove slowly, there are small components attached to the motor that could become loose and/or missing.
    • Lift up on the plastic housing located on the upper portion of the leg (where it connects to the body).
    • Carefully separate the plastic housing at the base of the leg.
    • Remove slowly, there are small components attached to the motor that could become loose and/or missing.
  8. The spring will be exposed as shown. Remove the broken or damaged spring and replace it with a new one.
    • The spring will be exposed as shown. Remove the broken or damaged spring and replace it with a new one.
    • Spring must be in the "loaded position" when reassembling (there should be some resistance).
  9. Pull motor out of pink wheel Remove pin (red), plastic piece connected to pin (orange), and plastic rim around motor (blue). Remove pin (red), plastic piece connected to pin (orange), and plastic rim around motor (blue).
    • Pull motor out of pink wheel
    • Remove pin (red), plastic piece connected to pin (orange), and plastic rim around motor (blue).
  10. Replace motor
    • Replace motor
Sonuç
David Tingley
85 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 9
Her zaman: 149
