Ana içeriğe geç
Zotac EN970 Storage Replacement
Neye ihtiyacın var
  1. Zotac EN970 Storage Replacement, Opening your machine: adım 1, 2 resimden 1. Zotac EN970 Storage Replacement, Opening your machine: adım 1, 2 resimden 2.
    • Zotac uses thumb screws to secure the case. No tools required!
    • After you remove the thumb screws, just slide the bottom cover away from you and lift it away.
  2. Zotac EN970 Storage Replacement, Insert your drive: adım 2, 3 resimden 1. Zotac EN970 Storage Replacement, Insert your drive: adım 2, 3 resimden 2. Zotac EN970 Storage Replacement, Insert your drive: adım 2, 3 resimden 3.
    • The EN970 has three hard drive connectors: 2 2.5" bays and 1 M.2 bay.
    • There are thumb screws for the 2.5" drives that secure plastic caddies that snap onto your drive
  3. Zotac EN970 Storage Replacement, M.2 Drive: adım 3, 2 resimden 1. Zotac EN970 Storage Replacement, M.2 Drive: adım 3, 2 resimden 2.
    • The M.2 drive requires a phillips screwdriver for installation. Your ZBOX should have two screws inserted in two of the three pegs.
    • Remove the screws, insert your drive and use one screw to secure it. Be sure not to over-tighten.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
zdowns1
247 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 1,359
