Ana içeriğe geç
Zune Flash 2nd Generation Back Cover Replacement
Neye ihtiyacın var
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
    FixBot'a Sor
    Yorum Ekle
  2. Zune Flash 2nd Generation Back Cover Replacement: adım 2, 2 resimden 1. Zune Flash 2nd Generation Back Cover Replacement: adım 2, 2 resimden 2.
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Zune Flash 2nd Generation Back Cover Replacement: adım 3, 1 resimden 1.
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Zune Flash 2nd Generation Back Cover Replacement: adım 4, 3 resimden 1. Zune Flash 2nd Generation Back Cover Replacement: adım 4, 3 resimden 2. Zune Flash 2nd Generation Back Cover Replacement: adım 4, 3 resimden 3.
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
    FixBot'a Sor
    Yorum Ekle
  5. Zune Flash 2nd Generation Back Cover Replacement: adım 5, 3 resimden 1. Zune Flash 2nd Generation Back Cover Replacement: adım 5, 3 resimden 2. Zune Flash 2nd Generation Back Cover Replacement: adım 5, 3 resimden 3.
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
    FixBot'a Sor
    Yorum Ekle
Sonuç
ybahman
139 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-20, Regan Fall 2009 Cal Poly, Team 9-20, Regan Fall 2009 üyesi
CPSU-REGAN-F09S9G20
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 4,228
