Ana içeriğe geç
Giriş
Guide for the removal and replacement of the communications board on the Zune Flash media player.
  1. Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure. If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images. You should hear a 'click' as the clip detaches from the device.
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Remove the two screws shown using a small Tri-Wing screwdriver.
    • Remove the two screws shown using a small Tri-Wing screwdriver.
    • You will need to use a very small Tri-Wing screwdriver to ensure that you do not strip the screws.
  4. Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device. Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device. Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside. Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside. Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
  6. Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver. Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
    • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
  7. Use your finger to pry back the two clear flaps. Slowly lift the communications board that was held down by the clear flaps.
    • Use your finger to pry back the two clear flaps.
    • Slowly lift the communications board that was held down by the clear flaps.
    • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
  8. Disconnect the ribbon cable with the Zune opening tool by flipping up the black plastic flap where the ribbon cable connects to the memory board.
    • Disconnect the ribbon cable with the Zune opening tool by flipping up the black plastic flap where the ribbon cable connects to the memory board.
    • Pull the ribbon cable out of the memory board.
  9. Peal the slim ribbon cable off the communications board using your fingers.
    • Peal the slim ribbon cable off the communications board using your fingers.
    • This slim ribbon is attached using an adhesive, so it cannot be reattached without more adhesive.
  10. Pull the cable connector straight up using your fingers. Communications board remains.
    • Pull the cable connector straight up using your fingers.
    • Communications board remains.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
ybahman
118 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-20, Regan Fall 2009 Cal Poly, Team 9-20, Regan Fall 2009 üyesi
CPSU-REGAN-F09S9G20
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 3,257
