Ana içeriğe geç
bObi Robotic Vacuum Front Wheel Replacement
Neye ihtiyacın var
  1. bObi Robotic Vacuum Front Wheel Replacement, Front Wheel: adım 1, 2 resimden 1. bObi Robotic Vacuum Front Wheel Replacement, Front Wheel: adım 1, 2 resimden 2.
    • Turn the front wheel so it faces bObi's front touch sensors.
    • Grip the wheel and pull straight up.
    • You may use a screwdriver for leverage when removing the wheel.
  2. bObi Robotic Vacuum Front Wheel Replacement: adım 2, 2 resimden 1. bObi Robotic Vacuum Front Wheel Replacement: adım 2, 2 resimden 2.
    • This step is only necessary when cleaning the wheel. Skip to step 4 for instructions on installing a new wheel.
    • To disassemble and deep clean the wheel, remove two small screws found on the bottom of the wheel. Then you can open it.
    • Grip the actual wheel and pull up to detach and clean beneath it. Use the screwdriver as leverage if you have difficulty separating the parts.
  3. bObi Robotic Vacuum Front Wheel Replacement: adım 3, 3 resimden 1. bObi Robotic Vacuum Front Wheel Replacement: adım 3, 3 resimden 2. bObi Robotic Vacuum Front Wheel Replacement: adım 3, 3 resimden 3.
    • This step is only necessary when cleaning bObi's front wheel. Skip to step 4 for instructions on installing the wheel.
    • After cleaning, replace the small spring piece inside the wheel.
    • Hold the wheel cover back together and install the two screws.
    • Place the small wheel back in its space and apply pressure until it reattaches.
  4. bObi Robotic Vacuum Front Wheel Replacement: adım 4, 1 resimden 1.
    • Place the wheel back in bObi. Make sure it faces in the same way as it did when removing (wheel closer to bObi's front).
    • Push down and the wheel will attach to bObi.
Sonuç
Chelsea
2.278 İtibar
31 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,467
