Ana içeriğe geç
Giriş
How to remove and replace the motor for bObi's main brushes.
Parçalar
Hiçbir parça belirtilmedi.
  1. bObi Robotic Vacuum Main Brush Motor Replacement, Main brush motor: adım 1, 3 resimden 1. bObi Robotic Vacuum Main Brush Motor Replacement, Main brush motor: adım 1, 3 resimden 2. bObi Robotic Vacuum Main Brush Motor Replacement, Main brush motor: adım 1, 3 resimden 3.
    • Remove bObi's dustbin. Press the small latch on the back and it will pop out.
    • Uninstall the 2 screws close to bObi’s dustbin, plus 2 smaller screws above the main brushes.
  2. bObi Robotic Vacuum Main Brush Motor Replacement: adım 2, 3 resimden 1. bObi Robotic Vacuum Main Brush Motor Replacement: adım 2, 3 resimden 2. bObi Robotic Vacuum Main Brush Motor Replacement: adım 2, 3 resimden 3.
    • To detach the brushes completely, unplug them from bObi.
    • The motor is on the bottom of the main brush attachment. Uninstall the four screws which secure it, then lift the motor out.
    • Remove the stabilizer attached to the motor’s end, closer to its circuit plug before pulling the whole piece out.
  3. bObi Robotic Vacuum Main Brush Motor Replacement: adım 3, 3 resimden 1. bObi Robotic Vacuum Main Brush Motor Replacement: adım 3, 3 resimden 2. bObi Robotic Vacuum Main Brush Motor Replacement: adım 3, 3 resimden 3.
    • Slide the long metal end in first, through the second stabilizer, so the end fits inside the motor holder.
    • Place the stabilizer you removed previously on the new motor.
  4. bObi Robotic Vacuum Main Brush Motor Replacement: adım 4, 2 resimden 1. bObi Robotic Vacuum Main Brush Motor Replacement: adım 4, 2 resimden 2.
    • Align the stabilizer with the screw posts on the brush holder, then install all four screws.
    • Connect the motor’s circuit plug.
    • Place the main brush attachment in bObi so it sits flat.
    • Line up the red fastener on bObi, and replace its two smaller screws.
  5. bObi Robotic Vacuum Main Brush Motor Replacement: adım 5, 2 resimden 1. bObi Robotic Vacuum Main Brush Motor Replacement: adım 5, 2 resimden 2.
    • Lay the two screw holders down. Then install each screw.
    • Slide bObi's dustbin back in until it locks in place.
Sonuç
Chelsea
2.278 İtibar
31 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 270
