Ana içeriğe geç
Giriş
For help closing bObi when the repair is complete, see Closing bObi's Cover Post-Repair
Parçalar
Hiçbir parça belirtilmedi.
  1. bObi Robotic Vacuum Power Switch Replacement, Top Cover: adım 1, 2 resimden 1. bObi Robotic Vacuum Power Switch Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Power Switch Replacement: adım 2, 3 resimden 1. bObi Robotic Vacuum Power Switch Replacement: adım 2, 3 resimden 2. bObi Robotic Vacuum Power Switch Replacement: adım 2, 3 resimden 3.
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Power Switch Replacement: adım 3, 3 resimden 1. bObi Robotic Vacuum Power Switch Replacement: adım 3, 3 resimden 2. bObi Robotic Vacuum Power Switch Replacement: adım 3, 3 resimden 3.
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Power Switch Replacement: adım 4, 3 resimden 1. bObi Robotic Vacuum Power Switch Replacement: adım 4, 3 resimden 2. bObi Robotic Vacuum Power Switch Replacement: adım 4, 3 resimden 3.
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Power Switch Replacement, Power Switch: adım 5, 3 resimden 1. bObi Robotic Vacuum Power Switch Replacement, Power Switch: adım 5, 3 resimden 2. bObi Robotic Vacuum Power Switch Replacement, Power Switch: adım 5, 3 resimden 3.
    • Slide the power switch up and out of its holder.
    • Unplug its wires from the main board.
  6. bObi Robotic Vacuum Power Switch Replacement: adım 6, 3 resimden 1. bObi Robotic Vacuum Power Switch Replacement: adım 6, 3 resimden 2. bObi Robotic Vacuum Power Switch Replacement: adım 6, 3 resimden 3.
    • Slide the new power switch into the holders on bObi.
    • Plug it in to the main board and begin closing bObi up. For steps on how to close bObi, see Closing bObi's Cover Post-Repair
Sonuç
To reassemble your device, follow the guide on closing bObi Closing bObi's Cover Post-Repair
Chelsea
2.278 İtibar
31 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 245
