Ana içeriğe geç
bObsweep Robotic Vacuum Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: adım 1, 3 resimden 1. bObsweep Robotic Vacuum Battery Replacement, Battery: adım 1, 3 resimden 2. bObsweep Robotic Vacuum Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: adım 2, 3 resimden 1. bObsweep Robotic Vacuum Battery Replacement: adım 2, 3 resimden 2. bObsweep Robotic Vacuum Battery Replacement: adım 2, 3 resimden 3.
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: adım 3, 3 resimden 1. bObsweep Robotic Vacuum Battery Replacement: adım 3, 3 resimden 2. bObsweep Robotic Vacuum Battery Replacement: adım 3, 3 resimden 3.
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: adım 4, 3 resimden 1. bObsweep Robotic Vacuum Battery Replacement: adım 4, 3 resimden 2. bObsweep Robotic Vacuum Battery Replacement: adım 4, 3 resimden 3.
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
Sonuç
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
Bir başkası bu kılavuzu tamamladı.
Tatiana
737 İtibar
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,803
