Ana içeriğe geç
creative ac adapter model maf115160th
Neye ihtiyacın var
  1. creative ac adapter model maf115160th, panel: adım 1, 2 resimden 1. creative ac adapter model maf115160th, panel: adım 1, 2 resimden 2.
    • panel view
    how to open the housing
    sard_chalakur - Yanıt
  2. creative ac adapter model maf115160th, inside view: adım 2, 1 resimden 1.
    • solder the new thermal fuse (or bridge) between the left and the middle contact (in the picture there is just a bridge -above the red tape-... (had no thermal fuse at hand at first...)
  3. creative ac adapter model maf115160th: adım 3, 1 resimden 1.
    • found one 85c in a used li-ion-pack... be VERY careful when soldering NOT to exceed the max. temp meanwhile--- suggest to put a final layer of tape around to get better contact to the coil -where the heat is coming from in case of overload-
    Where can i buy
    Rhos Ogalesco - Yanıt
Sonuç
close the lid and add eg thermo-glue or just use the soldering-iron and make the housing melt along the pits
8 farklı kişi bu kılavuzu tamamladı.
biopilz
465 İtibar
2 adet Kılavuz yazıldı
3 Yorum
My A300 speaker adapters has blown I need to get a new one
Sakhile Lloyd - Yanıt
Can you show me of this Adapter diagram. The middle line in primary is broken but i don’t know how to connect to which leg
Tien - Yanıt
Can I use the lead line instead of fuse to connected
Tien - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 7,610
