Ana içeriğe geç
d.light Solar Lantern S2 Battery Replacement
Neye ihtiyacın var
  1. d.light Solar Lantern S2 Battery Replacement, Battery: adım 1, 2 resimden 1. d.light Solar Lantern S2 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: adım 2, 3 resimden 1. d.light Solar Lantern S2 Battery Replacement: adım 2, 3 resimden 2. d.light Solar Lantern S2 Battery Replacement: adım 2, 3 resimden 3.
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: adım 3, 3 resimden 1. d.light Solar Lantern S2 Battery Replacement: adım 3, 3 resimden 2. d.light Solar Lantern S2 Battery Replacement: adım 3, 3 resimden 3.
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jeremiah Rhoades
435 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Harley Fall 2017 IUPUI, Team S2-G3, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G3
3 Üyeler
Bir Yorum
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 2,065
