Ana içeriğe geç
d.light Solar Lantern S2 Solar Panel Replacement
Neye ihtiyacın var
  1. d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: adım 1, 2 resimden 1. d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: adım 1, 2 resimden 2.
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Solar Panel Replacement: adım 2, 2 resimden 1. d.light Solar Lantern S2 Solar Panel Replacement: adım 2, 2 resimden 2.
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Solar Panel Replacement: adım 3, 2 resimden 1. d.light Solar Lantern S2 Solar Panel Replacement: adım 3, 2 resimden 2.
    • Desolder the yellow and black wires that connect the solar panel to the circuit board.
    • Remove the solar panel by pressing on the mounting clips (underneath fingers) using the spudger.
  4. d.light Solar Lantern S2 Solar Panel Replacement: adım 4, 2 resimden 1. d.light Solar Lantern S2 Solar Panel Replacement: adım 4, 2 resimden 2.
    • Solder the wires to the solar panel (positive to positive, negative to negative).
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeremiah Rhoades
435 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Harley Fall 2017 IUPUI, Team S2-G3, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 635
