Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This is where all of the power comes into the device. Learn how to replace it. Be careful while soldering!
Neye ihtiyacın var
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Locate the three solder connections for the electrical port.
Desolder the connection points following the instructions included with your soldering kit as you remove the port.
Bir başkası bu kılavuzu tamamladı.
