Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The motherboard is the heart and soul of any electronic device. Learn how to replace it!
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the rubber foot pads on the bottom of the device using a plastic opening tool. Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. Remove the six 2 mm PH0 screws on the bottom of the device. Four of those screws are located under the foot pads.
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Gently remove the bottom of the device.
    • Gently remove the bottom of the device.
  5. Remove the four 1.8 mm J1 screws. Remove the two 2mm PH0 screws.
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  6. Gently pick up the mother board
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  7. Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port. Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob
750 İtibar
6 adet Kılavuz yazıldı
Takım
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 124
