Ana içeriğe geç
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
Neye ihtiyacın var
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: adım 1, 2 resimden 1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: adım 1, 2 resimden 2.
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 2, 2 resimden 1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 2, 2 resimden 2.
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 3, 1 resimden 1.
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: adım 4, 2 resimden 1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: adım 4, 2 resimden 2.
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 5, 1 resimden 1.
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 6, 2 resimden 1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: adım 7, 2 resimden 1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: adım 7, 2 resimden 2.
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 8, 1 resimden 1.
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: adım 9, 1 resimden 1.
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob
757 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 196
