Ana içeriğe geç
Giriş
To complete this guide, you will need a PH 0 screwdriver and a spudger or similar prying device to access the interior of the Quad Dock Pro.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the rubber foot pads on the bottom of the device using a plastic opening tool. Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. Remove the six 2 mm PH0 screws on the bottom of the device. Four of those screws are located under the foot pads.
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. Gently remove the bottom of the device.
    • Gently remove the bottom of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob
750 İtibar
6 adet Kılavuz yazıldı
Takım
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 62
