Ana içeriğe geç
eMac Fan Assembly Replacement
Neye ihtiyacın var
  1. eMac Fan Assembly Replacement, Door Removal: adım 1, 3 resimden 1. eMac Fan Assembly Replacement, Door Removal: adım 1, 3 resimden 2. eMac Fan Assembly Replacement, Door Removal: adım 1, 3 resimden 3.
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Fan Assembly Replacement, Bottom Screw Removal: adım 2, 1 resimden 1.
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Fan Assembly Replacement, Top and Side Screws: adım 3, 3 resimden 1. eMac Fan Assembly Replacement, Top and Side Screws: adım 3, 3 resimden 2. eMac Fan Assembly Replacement, Top and Side Screws: adım 3, 3 resimden 3.
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Fan Assembly Replacement, Power Button Cable: adım 4, 2 resimden 1. eMac Fan Assembly Replacement, Power Button Cable: adım 4, 2 resimden 2.
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Fan Assembly Replacement, Shell Removal: adım 5, 1 resimden 1.
    • Now the entire shell can be removed from the computer.
  6. eMac Fan Assembly Replacement, Panel Removal: adım 6, 3 resimden 1. eMac Fan Assembly Replacement, Panel Removal: adım 6, 3 resimden 2. eMac Fan Assembly Replacement, Panel Removal: adım 6, 3 resimden 3.
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  7. eMac Fan Assembly Replacement, Cables: adım 7, 3 resimden 1. eMac Fan Assembly Replacement, Cables: adım 7, 3 resimden 2. eMac Fan Assembly Replacement, Cables: adım 7, 3 resimden 3.
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
  8. eMac Fan Assembly Replacement, Screws: adım 8, 2 resimden 1. eMac Fan Assembly Replacement, Screws: adım 8, 2 resimden 2.
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
  9. eMac Fan Assembly Replacement: adım 9, 1 resimden 1.
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
  10. eMac Fan Assembly Replacement, Assembly Removal: adım 10, 2 resimden 1. eMac Fan Assembly Replacement, Assembly Removal: adım 10, 2 resimden 2.
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chris Green
38.143 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
330 Üyeler
1.452 adet Kılavuz yazıldı
1Rehber Yorum
Does anyone know the names of connectors for the fan? I would like to power one externally if possible.
grantdavis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 53
Her zaman: 1,729
