Ana içeriğe geç
eMac PRAM Battery Replacement
Neye ihtiyacın var
    1. eMac PRAM Battery Replacement, PRAM Battery: adım 1, 2 resimden 1. eMac PRAM Battery Replacement, PRAM Battery: adım 1, 2 resimden 2.
      • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
      FixBot'a Sor
      Yorum Ekle
    2. eMac PRAM Battery Replacement: adım 2, 2 resimden 1. eMac PRAM Battery Replacement: adım 2, 2 resimden 2.
      • The access panel is held in place by one Phillips screw. Unscrew it.
      • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
      FixBot'a Sor
      Yorum Ekle
    3. eMac PRAM Battery Replacement: adım 3, 1 resimden 1.
      • The battery is located just to the left and below the RAM slots.
      • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
      • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
      • After removal of the old battery and replace with a new one by pressing it into place.
      • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
      • If no internet just set the date and time manually.
      • Next select the Time Zone box. Click the curser on the map to the closest city to you.
      • Next click the Clock box and select the type of display you prefer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
mayer
690.459 İtibar
11 adet Kılavuz yazıldı
1Rehber Yorum
Alguien sabe el.modo serie de la batería???? Todo muy bien pero faltó lomas importante el modelo serie o número de pieza de la bateria
ru vera - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 85
Her zaman: 24,914
