Ana içeriğe geç
eMac RAM Door Replacement
Neye ihtiyacın var
    1. eMac RAM Door Replacement, Door Removal: adım 1, 3 resimden 1. eMac RAM Door Replacement, Door Removal: adım 1, 3 resimden 2. eMac RAM Door Replacement, Door Removal: adım 1, 3 resimden 3.
      • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
      • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
      • Remove the single phillips #2 screw on the RAM door, and remove the door
      • The screw is captive in the door, so don't worry about losing it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chris Green
38.396 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
334 Üyeler
5.770 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 54
Her zaman: 1,399
