Ana içeriğe geç
eMac RAM Replacement
Neye ihtiyacın var
    1. eMac RAM Replacement, RAM: adım 1, 3 resimden 1. eMac RAM Replacement, RAM: adım 1, 3 resimden 2. eMac RAM Replacement, RAM: adım 1, 3 resimden 3.
      • The 700MHz thru the second 1 GHz models use PC 133 sticks. The maximum RAM is 1 GB. The second two 1 GHz models and higher machines use PC 2700 memory sticks and have a maximum RAM of 2GB.
      • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
      FixBot'a Sor
      Yorum Ekle
    2. eMac RAM Replacement: adım 2, 2 resimden 1. eMac RAM Replacement: adım 2, 2 resimden 2.
      • The access panel is held in place by one Phillips screw. Unscrew it.
      • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
      FixBot'a Sor
      Yorum Ekle
    3. eMac RAM Replacement: adım 3, 2 resimden 1. eMac RAM Replacement: adım 3, 2 resimden 2.
      • There are two RAM slots. Release the RAM by pushing the white outer tabs. Then pull the RAM straight out.
      • Place new RAM in slots and press with both thumbs on each end till you feel them seat.
      • Replace the access panel. Turn it over and plug it in. Boot the machine up and click the Apple logo in the menu bar and then go to "about this Mac", to check to see that the RAM is being recognised properly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
29 farklı kişi bu kılavuzu tamamladı.
mayer
690.441 İtibar
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 72
Her zaman: 22,257
