Giriş
Has your eMachine been running slow lately? Ready to upgrade to a higher memory size? This guide will show you how to remove the built-in Samsung random access memory (RAM) disks and install two DDR4 SDRAM memory disks.
Note that the size of your memory disks will need to be in DDR4 SDRAM bandwidth.
I will be using the Phillips #1 Screwdriver from my iFixit Pro Tech Toolkit.
Neye ihtiyacın var
Bu adımda kullanılan alet:Anti-Static Wrist Strap$7.95
Shut down the computer.
Disconnect all cables from the computer.
Bu adımda kullanılan alet:Phillips #1 Screwdriver$5.49
Place the computer upright at standing position.
Using a Phillips #1 Screwdriver:
Remove the two 1cm combination screws located on the right of the casing.
With the case panel open, locate the two RAM disk slots on the right side of the motherboard.
Locate the tabs on the RAM disks.
Use your index finger to release the tab at the bottom of the left RAM disk slot.
Use both hands to align the case panel to the case frame.
Once in place, push the case panel forward until it secures in place.
Using your Phillips #1 Screwdriver:
Screw the two 1cm combination screws back into place on the right side of the case panel.
And that’s all there is to it! Make sure to dispose your old RAM disks properly at your local recycling center.
