Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Yardım
Adım 9 Düzenleniyor —
Uyarı: Az önce incelediğiniz kılavuzun bir önkoşulunu düzenlemektesiniz. Yapacağınız herhangi bir değişiklik bu adımı içinde bulunduran 4kılavuzları etkileyecektir.
Adım Tipi:
Yeniden düzenlemek için sürükleyin
To reinstall the back cover:
Use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Be aware that this leaves gaps that are vulnerable to liquid intrusion.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
