Ana içeriğe geç
Yardım
Mac mini Model A1176 RAM Replacement
Öne Çıkan Kılavuzlar
Bu kılavuz, iFixit kadrosu tarafından acayip havalı bulundu.
Accessing the RAM requires the removal of the internal frame.
Adım 1 RAM  ¶
Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Adım 1 RAM  ¶
  • Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Adım 2  ¶
Pull the RAM chip directly out from its connector.
Adım 2  ¶
  • Pull the RAM chip directly out from its connector.
  • If there are two RAM chips installed, repeat the above procedure for the second chip.
