Ana içeriğe geç
Yardım
iPad 3 Wi-Fi Front Facing Camera Replacement
Replace the front facing camera in your iPad 3 Wi-Fi.
This guide will help you replace the front facing camera.
Bölümler
Aletler
Adım 1 Front Facing Camera  ¶
Peel back and remove the adhesive tape covering the headphone jack assembly.
  • Peel back and remove the adhesive tape covering the headphone jack assembly.
Adım 2  ¶
Using the flat end of a spudger, pry the front-facing camera off of its socket on the headphone jack assembly. Without removing the spudger, slide the spudger to the right, releasing the adhesive holding down the camera ribbon cable.
Adım 2  ¶
  • Using the flat end of a spudger, pry the front-facing camera off of its socket on the headphone jack assembly.
  • Without removing the spudger, slide the spudger to the right, releasing the adhesive holding down the camera ribbon cable.
Adım 3  ¶
Use the flat end of a spudger to pry the camera ribbon cable out of its socket in the plastic antenna housing. Use the flat end of a spudger to pry the camera ribbon cable out of its socket in the plastic antenna housing.
Adım 3  ¶
  • Use the flat end of a spudger to pry the camera ribbon cable out of its socket in the plastic antenna housing.
Adım 4  ¶
Remove the camera from the iPad.
Adım 4  ¶
  • Remove the camera from the iPad.
