Ana içeriğe geç
Yardım
Toro Lawn Mower Cutting Blade Replacement
This guide will help to accomplish the replacement of the blade on a Toro Lawn Mower to ensure that the unit is cutting grass effectively.
Replacing the cutting blade on a lawn mower is important to ensure that your grass is cut correctly and that your lawn mower is running efficiently. This is a simple fix that requires little to no expertise or previous experience. Just make sure to be careful when handling the blade itself and all should run smoothly.
Adım 1 Cutting Blade  ¶
Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
  • Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
Adım 2  ¶
Flip the mower onto its side exposing the blade and under carriage.
Adım 2  ¶
  • Flip the mower onto its side exposing the blade and under carriage.
Adım 3  ¶
Place wood in between the blade and the wall of the mower to ensure that the blade does not move while you are tightening or loosening the bolt.
Adım 3  ¶
  • Place wood in between the blade and the wall of the mower to ensure that the blade does not move while you are tightening or loosening the bolt.
Adım 4  ¶
Using the 5/8 wrench, turn the blade counter clockwise until the bolt is loose then pull the blade off.
Adım 4  ¶
  • Using the 5/8 wrench, turn the blade counter clockwise until the bolt is loose then pull the blade off.
  • Make sure that safety gloves are worn at all times when handling the new or old cutting blade.
Adım 5  ¶
Place the new blade in right side up into the bracket and line up the bolt.
Adım 5  ¶
  • Place the new blade in right side up into the bracket and line up the bolt.
  • Make sure that safety gloves are being worn at all times when handling either the new or old cutting blade.
Adım 6  ¶
Using the 5/8 ratchet, turn the bolt clockwise until the bolt does not turn anymore.
Adım 6  ¶
  • Using the 5/8 ratchet, turn the bolt clockwise until the bolt does not turn anymore.
Adım 7  ¶
Flip the mower right-side up and reconnect the spark plug.
Adım 7  ¶
  • Flip the mower right-side up and reconnect the spark plug.
