Ana içeriğe geç
Yardım
iBook G4 12" 800 MHz-1.2 GHz LCD Replacement
Replace a broken LCD/Backlight with the display still attached to your iBook.
Bölümler
Dosyalar
Aletler
Adım 1 LCD  ¶
Close the display. Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
Adım 1 LCD  ¶
  • Close the display.
  • Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
  • Remove the large piece of tape near the right display hinge.
Adım 2  ¶
Remove the tape covering the inverter cable connector. Remove the piece of foil tape near the center of the thin metal LCD cover.
Adım 2  ¶
  • Remove the tape covering the inverter cable connector.
  • Remove the piece of foil tape near the center of the thin metal LCD cover.
Adım 3  ¶
Remove the Phillips screw near the right display hinge. Use the tip of a spudger to remove the small spacer under the screw you just removed.
Adım 3  ¶
  • Remove the Phillips screw near the right display hinge.
  • Use the tip of a spudger to remove the small spacer under the screw you just removed.
Adım 4  ¶
Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover. Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
Adım 4  ¶
  • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover.
  • Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
Adım 5  ¶
Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total). Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
Adım 5  ¶
  • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
Adım 6  ¶
Carefully remove the thin steel LCD cover.
Adım 6  ¶
  • Carefully remove the thin steel LCD cover.
Adım 7  ¶
Remove the long piece of tape securing the display data cable to the LCD. Disconnect the display data cable by pulling the cable away from the socket on the LCD.
Adım 7  ¶
  • Remove the long piece of tape securing the display data cable to the LCD.
  • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
Adım 8  ¶
Disconnect the backlight cable from the inverter.
Adım 8  ¶
  • Disconnect the backlight cable from the inverter.
  • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
Adım 9  ¶
Open the display. Lift the LCD out of the display assembly. Lift the LCD out of the display assembly.
Adım 9  ¶
  • Open the display.
  • Lift the LCD out of the display assembly.
