Ana içeriğe geç
Yardım
iPad Mini CDMA Logic Board Assembly Replacement
Salt Önkoşul
Salt Önkoşul
Bu kılavuzun yalnızca diğer kılavuzlar için bir önkoşul kılavuzu olduğunu lütfen dikkate alın.
Prereq for disconnecting all connectors from logic board.
Adım 1 Logic Board Assembly  ¶
Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector. Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  • Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
Adım 2  ¶
The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates. Use a plastic opening tool to gently pry the upper metal plate up from the front-facing camera cable connector.
Adım 2  ¶
  • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
  • Use a plastic opening tool to gently pry the upper metal plate up from the front-facing camera cable connector.
  • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
Adım 3  ¶
Gently pry the second (lower) metal plate up from the front-facing camera cable connector. Again, carefully pry the plate up and away from the front-facing camera cable connector.
Adım 3  ¶
  • Gently pry the second (lower) metal plate up from the front-facing camera cable connector.
  • Again, carefully pry the plate up and away from the front-facing camera cable connector.
Adım 4  ¶
Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board. Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
Adım 4  ¶
  • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
Adım 5  ¶
Gently fold the front-facing camera cable up and out of the way of the logic board. Gently fold the front-facing camera cable up and out of the way of the logic board.
Adım 5  ¶
  • Gently fold the front-facing camera cable up and out of the way of the logic board.
Adım 6  ¶
Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector. Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
Adım 6  ¶
  • Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
Adım 7  ¶
Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector. Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
Adım 7  ¶
  • Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector.
  • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
Adım 8  ¶
Pry the second (top) metal plate up from the front-facing camera cable connector. Again, carefully pry the plate up and away from the headphone jack cable connector.
Adım 8  ¶
  • Pry the second (top) metal plate up from the front-facing camera cable connector.
  • Again, carefully pry the plate up and away from the headphone jack cable connector.
Adım 9  ¶
Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board. Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
Adım 9  ¶
  • Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
Adım 10  ¶
Gently bend the headphone jack cable back, away from the logic board. Gently bend the headphone jack cable back, away from the logic board.
Adım 10  ¶
  • Gently bend the headphone jack cable back, away from the logic board.
Adım 11  ¶
Use a plastic opening tool to pry the top left antenna cable up from its socket on the logic board. Use a plastic opening tool to pry the top left antenna cable up from its socket on the logic board.
Adım 11  ¶
  • Use a plastic opening tool to pry the top left antenna cable up from its socket on the logic board.
Adım 12  ¶
Remove the following three screws securing the top right antenna to the rear case:
Adım 12  ¶
  • Remove the following three screws securing the top right antenna to the rear case:
  • Two 1.3 mm #00 Phillips screws from the side of the antenna's socket.
  • One 1.8 mm #00 Phillips screw.
Adım 13  ¶
Disconnect the top right antenna's coaxial cable from the logic board with a plastic opening tool. Gently bend the cable and screw tab up out of the way of the logic board. Gently bend the cable and screw tab up out of the way of the logic board.
Adım 13  ¶
  • Disconnect the top right antenna's coaxial cable from the logic board with a plastic opening tool.
  • Gently bend the cable and screw tab up out of the way of the logic board.
Adım 14  ¶
Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board. Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
Adım 14  ¶
  • Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
Adım 15  ¶
Pry the top right antenna's ribbon cable up from its socket on the logic board with a plastic opening tool. Pry the top right antenna's ribbon cable up from its socket on the logic board with a plastic opening tool.
Adım 15  ¶
  • Pry the top right antenna's ribbon cable up from its socket on the logic board with a plastic opening tool.
Adım 16  ¶
Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector. Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
Adım 16  ¶
  • Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
Adım 17  ¶
Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector. Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
Adım 17  ¶
  • Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
Adım 18  ¶
Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board. Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
Adım 18  ¶
  • Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
Adım 19  ¶
Gently peel back the wide piece of tape covering the top of the right speaker. Gently peel back the wide piece of tape covering the top of the right speaker. Gently peel back the wide piece of tape covering the top of the right speaker.
Adım 19  ¶
  • Gently peel back the wide piece of tape covering the top of the right speaker.
Adım 20  ¶
Continue peeling the tape, and remove it from the iPad. Continue peeling the tape, and remove it from the iPad. Continue peeling the tape, and remove it from the iPad.
Adım 20  ¶
  • Continue peeling the tape, and remove it from the iPad.
Adım 21  ¶
Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board. Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board. Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
Adım 21  ¶
  • Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
Adım 22  ¶
Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad. Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
Adım 22  ¶
  • Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad.
  • Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
Adım 23  ¶
With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case. Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
Adım 23  ¶
  • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
  • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
Adım 24  ¶
Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip. Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip. Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
Adım 24  ¶
  • Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
Adım 25  ¶
De-route the antenna cable from the corner of the iPad. De-route the antenna cable from the corner of the iPad.
Adım 25  ¶
  • De-route the antenna cable from the corner of the iPad.
Adım 26  ¶
Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad. Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
Adım 26  ¶
  • Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
Adım 27  ¶
Peel the cable back from the corner of the iPad.
Adım 27  ¶
  • Peel the cable back from the corner of the iPad.
Adım 28  ¶
Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad. Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing. Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
Adım 28  ¶
  • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
  • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
Adım 29  ¶
Pull the antenna cable from the slot behind the Lightning connector. Pull the antenna cable from the slot behind the Lightning connector.
Adım 29  ¶
  • Pull the antenna cable from the slot behind the Lightning connector.
